Hybrid analog/digital preamp?
With the speed and availability of digital processing power, I was thinking that a simple one stage preamp with maybe one of the RIAA time constants feeding a DSP programmed to do the rest would be an interesting project. I'm sort of thinking out loud over my morning coffee.
Perhaps such a thing could be one part of a whole family of dedicated widgets??? (e.g. the AD1954 or some of the alesis products). It would be great to see more dedicated "black box" type devices that could be easily integrated by "non-dsp designers"......
Hey, if you had some "in" at a place like Analog Devices I'll bet you could make it happen..........🙂 🙂 🙄
Meanwhile, I'm still waiting for my AD1954 samples to play with.🙂
Regards,
Bill
Came across this old post randomly, but this hybrid approach is something I've been thinking about as well since recording my vinyl to cd/dvd is a project on my todo list.
I've actually been thinking about a fully-digital approach where you just run the 'table through ~60dB of gain and apply the full RIAA digitally, but I just can't bring myself to believe that this is optimal - I'm not sure you end up with enough S/N performance in the treble after applying the filters. OTOH the midrange and treble will be at a (relatively) higher level before digitizing so you (in theory) get more 'bits' of resolution on the initial capture than when using an already-corrected signal.
The idea of applying the 50Hz section in the preamp to get 'into the ballpark' and then correcting digitally seems to be a promising idea - the phono 'pre' can be much simpler (ie cheaper) than a full RIAA approach, and you only need moderate digital correction to complete the eq.
One of the big practical factors might be the ability to handle pops/ticks - recording a pre-equalized signal will result in much lower energy from pops/clicks than if you record the un-equalized signal, which might help to avoid clipping during recording.
Anyone actually end up trying this or something similar?
Exactly. A low-pass 3180us filter (shelving at 3.18us) would equalise the velocity response of the transducer, and the fiddly 318us, 75us could be done very precisely with digits.
Reply to myself: I can probably try that out easily with my Behringer Ultradrive Pro 2496, which surely has the required filter options. All that is needed is a flat pre ahead of it. And a turntable, of course. So, how about taking a RIAA preamp, removing the correction stuff (maybe leave in the 3.18uS low pass), leaving a flat gain block, and sticking its output in a Behringer?
Jan Didden
janneman said:
Scott,
I would be worried about loosing quality by going ADC - DSP - DAC.
Anyway, purist LP/vinyl lovers would probably come after you with a hatchet for this blasphemy.😉
Jan Didden
Well, the idea really only makes sense in the context of digitizing vinyl in the first place. I've ended up going with a completely digital system (using the Panasonic Digital receivers and homebrew digital xovers), and so recording the vinyl at 24/96 and burning to DVD-V is probably my best practical compromise.
I'd agree that deliberately introducing a spurious AD/DA cycle is pretty pointless.
Vinyl Lovers are well-balanced, kind and peaceful people, I think they won't :snoopy:
We-ell, but think about recordings with different/historic filtering, well performing analog solutions with switchable filter curves are quiet expensive, so a programmable system with memory banks can be quíet advantageous!
Rüdiger
