HV CCS question
OK. I was thinking to a cascoded DN2540 but having just two of them I looked for an alternative (FET) to link right below. Don't mind if I don't get the same performance, also a happy medium between the cascoded and the single one is welcome.
I don't like DN2540 as upper transistor, burnt a lot, now using IXTP 01N100D with great success.
As lower transistor:
2SK170/LSK170
2SK3557
CPH3910
N.B.
Always Idss of lower transistor must have more mA than device target
IXT gate stopper use CC like Arcol, 100R are perfect and not expensive
Be sure the Grade of lower transistor to ensure you can get your CCS target
Bela paralleled 4R7 to 2R2 of right channel, time to listen.
If I don'like the sound, I will order 10R Mundorf M-Resist 20W & I will change the power tx for the LL1683 to have 250V in place of the Bartolucci 125VAC to get the typical bias 140-150V 9V 6mA or don't worth the work because the sound don't will increase the SQ, what's your opinion?
"why the 6V of difference between valves matched with a difference of 0.02mA!!!!"
It's only static parameter, but correlating with tube condition.
With same bias, same current the anode voltages differs: one tube weaker, than another, emits lesser electrons.
If you measure gm, the tube where Ua is lower (it's stronger) shows higher gm.
For example I measured several 801/801a tubes: fixed Ug (-9V), fixed Ia (400V B+, 18mA CCS).
The minimum and maximum Ua was 158V and 232V.
These tubes gm was 1810 and 1639.
If it (different Ua) bother you, try to change 2R2 (for example paralleling with 10R...4R7), to changing bias.
The anode voltage will changing, but tube's gm practically remains as above (mutual conductance would changing about 5% -see datasheet-) , so one tube will produce a little lower output than another.
Thanks for the explanation, now makes sense.
No.
Use same anode current (CCS), and slightly change in one channel the filament bias (decreasing 2R2, increasing Ua).
It deals less damage than using its with different current.
1.) But before do anything: are you measured both channels with the same (for example 1V) input? Is noticeable (few dB) difference between output voltages?
2.) Are you tested both tubes in the same channel (measured static voltage, anode current, and mostly output volume)?
No I don't but I will do later, that's a good way to see if the gain is more or less the same in both tubes, thanks.
Hello, maybe I'm going a little off-topic...what kind of CCS could be suitable for this circuit section below? Current about 10-12mA. Thanks
What's the role of R1 (33R) series with the LED?
U= 33*0.01 only 330mV, it can be omitted, if you choose another (higher saturating voltage at 10mA) LED.
Each (AC unblocked) series resistance increase the dynamic impedance of cathode complex, so should be avoided if possible.
E180F is happy with 2V bias, so -old type- red or green LED is perfect for this purpose.
Do you believe the general bias used by you and others 140-150V 9V 6mA will increase the sound quality?
The #26 linearity almost the same in 4-6mA, 100-150V range .... if you use good working CCS and clean bias.
Are you sure, you tested CCS with different B+ voltages as I suggested in #46 post?
If CCS not working perfectly (for example setting it to 6mA the real CCS loaded tube MUST to work at 6mA -if bias does not disable it-), the loadline of the tube isn't horizontal, so anything can happen.
The good linearity is necessary condition, but does not guarantee "sound quality".
If the preamp sounds bad, something other problem could perform: HF oscillation, bias disturbance, overloading, PSU oscillation etc. etc.
The detailed measurement with signal generator and oscilloscope is mandatory.
Euro21, you are right but the red led I'm using is an old tipe (square shape) with a Vd of about 1.65V at normal conditions. If you consider 10mA on the cathode to reach 2V the resistor is needed, based on the op. point of the loadline (V=165-170V). Am I wrong?
2SK170/LSK170
2SK3557
CPH3910
N.B.
Thanks for you suggestion Merlin, the only thing is to see if IXTP 01N100D is easily available here (Italy). About the rest, I agree about the restriction of the Idss on the 2nd fet (transistor).
Am I wrong?
I mean "old": real old. I have 40 years old 5mm diameter LEDs. 🙂
At 10mA the red ones forward voltage average is 1.89V, the green has 2V.
The red has slightly lower dynamic resistance (dV/dI) than green (below 10mA).
I usually use LED bias only for CCS or "gyrator" loaded tube.
BTW the "new" Kingbright L-7104 series LED are also good ... if you use it with constant current.
Yes, they are about forty years old... as a recovery from old appliances with a square led vu-meter. Among the various LEDs tested they seem to me the most linear (even if I have made approximate measurements).
I've already spotted Knightbright's you mentioned on the bay, if they are not only sold from the UK due to customs I might give them a try.
Just out of curiosity, can you maybe post the gyrator/CCS circuit you used? 🙏
