what you suggest for +B (300-400V) for a connector(jack and plug)
I was looking at the Neutrik powercon but I don't think they are rated
beyond 250V.
I would like to house the PSU seperate from the main tube pcb.
Is there any issue with running seperate DC heater as well?
Is 2 feet too long for the HV power cable?
Thx
beyond 250V.
Thx
Hi!
I use Amphenol MS series connectors. They are available with various numbers of pins.
I routinely use external PSUs. No probelm to also have the DC heater supply external. I always keep the last LC stage for each voltage in the amp chassis. Even long umbilical runs are no problem this way
Best regards
Thomas
Best regards
Thomas
Do you use 2 or 3 conductor, shield?
I guess for H.V. it is better to use Teflon twister pair?
Excellent advise. Thanks.
You can also consider an octal plug on the umbilical, plugging into
a female socket on the chassis.
8PB Cinch 5935-00-061-7250 Octal Plug-in Socket
Hi!
Depending on the number of voltages I have, I use 5, 7 or up to 10 pin connectors.
Minimum is 5:
B+
Ground
2 wires for heater
safety earth
I use umbilicals with a common shield around all conductors. I connect the shield on the PSU side to saftey ground.
Best regards
Thomas
Minimum is 5:
B+
Ground
2 wires for heater
safety earth
Best regards
Thomas
