Humming Noise, Problem?
I have an Accuphase E202 amp, it has all new electrolytic capacitors on every circuit board in the amp, along with 4 new 10000uf 80v power capacitors. The amp makes a humming sound when powered up, but when the relay clicks, it's dead quite, works 100% perfect. Is this something that needs to be taken care of?
How do I fix it? 😕
The output of the amp is floating till the relay kicks in...maybe the amp is oscillating until a load is connected.
The output should be scoped. The relay can even be removed so that the amp can be left to float for troubleshooting purposes.
