I did some testing - the scary way, connect and pray! Well, I can say that I managed to get rid of the ground loop. My solution:
I'm sorry for not being able to share the schemiatics, but I think they are available at Dantimax's homepage.
The serial connector has five pins going to common ground on JP5 (relvol3) and JP1 (input2). I disconnected these. The only ground connected was from the junction where the RCA ground connects to the input2 ground (which is common ground for input2 card). This means that there is only one ground from input2 to relvol3.
I don't how or why, but it is dead quiet even with 0 dB connected to source that is not playing. Seems like the problem is fixed.
low level bzzzzzzzzzzzzzzzzzzzz
Hi guys,
I finished my Aleph-P and its connected to a Mini-P. Here's the story;
With a bought pre, there's no hum absolutely dead quiet. But with the Aleph-P, I'm getting a very low level bzzzzzzzzzz (bumblebee flying kind of sound) coming from both tweeters. I'm pretty sure its not a ground loop?? You can hear it at about ~0.5 away from the speakers.
I tried switching to a single transformer winding as I thought it might be the capacitive parasitics from the transformer (searched from another thread) but it didn't help either.
Does anyone have any ideas? Or even where to begin?
Thanks all!
Hi guys,
Thanks all!
Re: low level bzzzzzzzzzzzzzzzzzzzz
I think 90% so.
Re-check the ground loop.
rchua77 said:bzzzzzzzzzz
a ground loop??
I think 90% so.
as i find out now is the aleph=p has too much gain so the hum coming up if you put a post at the out put side,it will take the hum out . the input is for the signa in directly
please have a try the signa have to be big and aleph-p will do the amplification then the volumen will make the sound as loud as you like
Oh I forgot one more thing if its important, the bzzzz is constant with volume. e.g. with no source connected, when I turn the volume from min to max, the bzzz remains constant. I am guessing if there's a ground loop, it varies with volume yes?
rchua77 said:I am guessing if there's a ground loop, it varies with volume yes?
No. the bzzz remains the same at whatever the volume level is.
I would re-check the gnd loop.
And, further whether there is any soldering point defect.
Do you have volume on input or output?
I noticed with Aleph P that with the volume on the input i got low mosfet noise..
However, when volume is on the output there is no noise at all.
Soo,, with Aleph P, volume on the output is the choice if have the correct value ( or close enough)
/Z
/Z
volume is on the output.
For checking the ground loop, any hints? I can't seem to spot any... I'll try to get a wiring diagram up soon.
BTW, would a diode bridge to break the ground up be useful in this context?
rchua77 said:For checking the ground loop, any hints?
Possible hint only when we see the wiring diagram.
where do the input returns link into?
Similarly,
where do the vol pot returns link into?
I suspect when you add these, a few loops will become evident.
If this is the case then I think this could be solvable by separating the L & R audio grounds from each other and from the safety earth.
Similarly,
if your ancilliary equipment connects any input or output ground to safety earth then your diagram will have a ground loop.
Similarly, if any pair of inputs or outputs have the returns connected together externally then again your diagram has a ground loop.
I think the only way to make your diagram work with all combinations of ancilliaries is to separate the left ground from the right ground and to resistively connect each audio ground to safety earth.
Is you star ground a copper/aluminium plate? Try individual solder lugs (one to every ground wire) bolted together.
rchua77,
I would cut off the gnd lines arranged btwn PS and the amp PCB.
If you need the gnd on the amp PCB, you send them directly to the star,
not through the PS board.
And, I'd like to recommend the thermistor btwn the SE and the star.
I hope the skech explains better. Good luck!
tze-hao yen said:volumen should have a ground too
Open your eyes big, tze-hao.
The sketch has the output volumes and their grounds.
You are drinking too much ^^~
- Hum with aleph P
