I have a Fender-style preamp with one 12ax7.
It gives me hum which seems to be related to the power supply. It sounds like this:
(normalized).
It's not unbearably loud, I would say it's liveable, but it still is really annoying.
The thing is when I disconnect it from the mains, I get a few seconds of absolutely beautifully hum-free (while there is a charge in the capacitors) guitar sounds.
I believe the preamp circuit doesn't have ground loops (for every ground point in the circuit I have a separate track going to one single point which is connected to the power supply's 0V). The power supply I use is https://www.aliexpress.us/item/1005005909458258.html (seems to be pretty solid).
I have tried a huge 8 Henry choke on the 300V output of the power supply. I have tried balancing the output signal with the transformer (hoping the balanced result will cancel this hum), but nothing seems to help, the hum is still there. I have even dangerously tried to temporarily disconnect the mains earth connection (just to quickly check) and the noise gets much worse when I do that.
I would prepare myself for living with it if not for these beautiful few seconds of beautiful quietness when I disconnect it from the mains...
Could someone help identifying the problem (and finding the solution)?
Thanks.
Thanks.
It's a clean channel of Dumble ODS from here:
Without JFET circuit on the input, and without PAB switch. a part that starts with RV1-7 33k resistor and ends with C12 0.05f capacitor (of course followed by the Master POT, with the difference that I have a 500K pot instead of 1M).
From the power perspective, from this schematics, I use a 20u capacitor that's on B+4, then I have the same 2.2k resistor to B+5 and a couple of 10u capacitors on B+5. The power supply's 300V is connected to the B+4 point (everything before is of course omitted), 12ax7 is fed from the B+5 point (everything after B+5 is also omitted).
I haven't connected heater and HV grounds. I have just tried and it doesn't help. I also remember reading that they shouldn't be connected.
Heaters shall never be floating. They need to be somehow referenced to ground, or elevated.I have just tried and it doesn't help. I also remember reading that they shouldn't be connected.
The signal is coming out from C12, right?
I assume you do not have an oscilloscope. Can you use a sound analyser app with your sound card, like REW?
https://www.diyaudio.com/community/threads/how-to-distortion-measurements-with-rew.338511/
It can show the the hum frequency components.
Yes, it happens when the input is shorted too.
I actually have recently received a thing called FNIRSI DPOX180H (handheld oscilloscope).
It's just I haven't figured out how to use it yet. Perhaps the time has come . Just need to figure how what and where I should measure...
Start with the output signal, after C12.Just need to figure how what and where I should measure...
The preamp is mono. I currently use it with the transformer on the output (10k:10k transformer). Primary outer legs are connected to the preamp output/ground, secondary outer legs are connected to left/right channels of the stereo input and center tap is connected to the sound card input ground. Then in the digital domain I multiply the value of the right channel by -1 and sum it with the left channel. But I get the same hum even if I connect just one single channel without transformer.
Should I just connect the probe to the output of C12 and hit auto? What am I looking for?
@jcalvarez thanks for your help. It seems like I've solved the problem. It was the power supply's fault. I've got another one (https://www.aliexpress.us/item/3256806060916473.html) which is a bit smaller and seems less solid, but the hum is gone with it! This time I really seem to have my PCB circuit right . The downside of the new power supply is a bit of mechanical high pitched sound (the one that is typical for the switching power supplies), but I suppose it will be negligible once I have it boxed.
Great success! (as Borat would say )
I have one of those power supplies that gave you hum. I tested it quickly a while ago, did not find anything wrong with it. I guess you got unlucky. Funny, I was yesterday looking at the new one you bought. Seems similar, but with lower power.
- Tubes / Valves
- Hum identification
