Thank you,
I would like to make a definative and informative answer available to all that have searched this question (including me) with a one thread answer
Assuming all is ok with your grounding (star etc), and the chassis will be earthed for safety and only a loop is the problem.
We want to conect ground to earth but prevent a hum path
your opinions, diagrams and explinations on the following please:
a) why is there a need to conect ground to earth (floating / non floating)
b)[a]some have used a bridge between ground and earth, type and specs of bridge (part No.) with drawing and explination please
...some have used a bridge with other components between ground and earth, type and specs of bridge and components (part No's.) with drawing and explination please
c)some have used 2 diodes between ground and earth, type and specs of diodes (part No.) with drawing and explination please.
d)some have used a thermistor (CL60 ?) between ground and earth, type and specs of thermistor (part No.) with drawing and explination please
e)some have used a resistor (x ohm x watt) between ground and earth, type and specs of resistor with drawing and explination please
f) other ....
Please include your complete answers here so as all is in one spot.
Thank you all for your help in advance and I hope this will help those that are suffering or have suffered
f) other ....
