hpbuilder introduction
Good evening to all! I join diyaudio to learn how to rebuild existing loudspeakers and share my knowledge about building loudspeakers from scratch. Currently rebuilding Infinity Kappa 9 loudspeakers and will require advice from members. So far I have built open baffle, h-frame and closed loudspeakers. I have also modified a 3-way loudspeaker to active crossover with satisfying results. My mother tongue is french and I may express myself in odd ways. Thanks for letting me in!
stv, I hope you find your answers on this site for the ideal bass reflex port. Bass reflex loudspeakers are on my list of things to learn. To you, what is the ideal compared to:
Fb=v/(2∗π∗√(Vb∗ρ/A))Fb=v/(2∗π∗√(Vb∗ρ/A))
Variables:
  • Fb is the tuning frequency of the bass reflex speaker
  • v is the speed of sound in air (approximately 343 m/s)
  • π is a mathematical constant whose value is approximately 3.14159
  • Vb is the volume of the speaker box
  • ρ is the density of air (approximately 1.2 kg/m³)
  • A is the cross-sectional area of the port
I copied this from https://calculator.academy/bass-reflex-calculator/
hpbuilder
