HowTo: Kali Reclocker and Kodi without sync issues
Hello everyone. I somehow managed to get Kodi to work without the a/v sync issues because of the ~0.7s delay introduced by the Kali reclocker. What I did as follows:
  • Go to Settings (gear icon) -> System Settings -> Audio
  • Set "Output Configuration" to "Fixed"
  • Set "Limit Samping Rate" to "192"
That is all that I needed to do. Not sure why it works: If the buffer delay is still there and Kodi just delays the video or if it is the audio that now plays in realtime because somehow the Kali does not use its buffer in this case.
I will know which of the two when I test moonlight embedded as it requires realtime audio.
