Sorry I dont have anything better to show off at the moment😛 Since I had the saw lugged out I figured Id whip one together for someone complete with stainless steel roof. Im sure the birds will crap on something I own for it. Oh well, they gotta eat too I suppose.
I thought it was a bird TRAP.
Did you debur the stainless?
I was lazy and just bought one.
The screen cylinder.
I thinking of modding it by adding dowel or two
through it so birds can stand on it.
But then I had to move it around for the birds to find.
Squirrels found it first.
I adjusted its height.
Then squirrels came from the roof down.
Now they can't get to it.
I have the little **** birds sparrows.
But
now I've got
Morning Doves: ring neck, regular and white tip?
Cardinal family
Finches
Red Headed Woodpecker family
Squirrels underneath
But
now I've got
Cardinal family
Finches
birds to find.
But
now I've got
Cardinal family
Finches
A trap, did I close it in too much? I kinda thought it looked like a bar. I was going to make some stools for ***** and giggles. I cut the ss with a zip wheel it was pretty sharp, took care of that.
Squirrels used the house 3 out of 4 times something has nested in it. They took it upon them selves to chew a bigger entrance door, destructive little bastads. I dont mind them though.
Is that treated pine and, if so, did you check that it was safe for birds?
Abs
Its cedar and mostly treated pine. I did not check 😕
Though the inner base is untreated pine, I didnt plan that but at least the seed wont soak on the treated stuff if that helps.
I wouldnt want birds to start dropping out of the sky so I got foil trays that fit in the bottom. And removed the front pieces to open it back up. You were right SyncTronX 😉
- Member Areas
- The Lounge
- how you like my bird feeder
