Hi to all..
I'm build some SMPS Push-pull topology. BUt i've the following doubt...
How I should wrap the tranformer?
Case 1)
SECONDARY2
SECONDARY1
PRIMARY2
PRIMARY1
CORE
Case 2)
SECONDARY2
PRIMARY2
SECONDARY1
PRIMARY1
CORE
What's the correct one?
Case 1)
SECONDARY2
SECONDARY1
PRIMARY2
PRIMARY1
CORE
Case 2)
SECONDARY2
PRIMARY2
SECONDARY1
PRIMARY1
CORE
xfr
Interleave the primaries and secondaries as many times as possible. Reduces leakage inductance. WE typically split our high frequency switching supply transformers into 3 primary and 3 secondary windings.
So lay primary 1, then sec 1, pri 2, sec 2, pri 3 and last sec 3
Steve
Steve
Interleaving is only good for transformers driven by H bridge. If the topology is of the centre tapped primary type, there will be small mismatches between the two primary windings causing gradual shift towards saturation. If the centre tapped primary type is to be used you should wind bifilar, i.e. two runs of wire wound at same time.
- Power Supplies
- How wrap transformer...
