How to wire a DVC Sub?
Hi there,
I know this may sound stupid but I'd rather ask it than risk my amp.
I have one (1) 12" Sub with dual 8 ohms coils. Now, how do I wire it to my amp? Can I use the first coil for the left amp channel and the second coil for the right amp channel? I mean using a stereo power amp to power 1 dual voice coil sub.
My amp has a stereo/mono switch btw. :nod:
Any suggestions?
JojoD
you can use the left to power one coil and the right to power the other coil BUT the inputs for the left and right have to be the same channel either the left or right. if you don't one coil will blow up because the amplifier might tell it to go one way and the other to go the other. meaning BROKEn voice coil.
i would bridge the amplifier and run the coil in parallel.
Lets say you have a REALLY strong amp and you put 50 amperes into the 8ohm coil. Force generated by the motor is Bli and Bl~10 so about 500 Newtons - 10Newtons is ~2 pounds so ~100lb.
For a more typical amp the force is perhaps 10lb.
The dual voice coils are interleaved, not separate, so you are not likely to "break" the coil.... 😉
Lots of speakers use a DVC sub driven by stereo signal. It will be fine.
if one coil is going one way,and one coil the other,that means that the bass signal must be opposite.
i dont think much bass is in antiphase across left and right channels
-or did i completely miss the point
ron E nice point i love equations heheh FBI <points hand with flux being the thumb,i the 3nd finger, etc etc.. >:clown:
Don't worry about 2 different signals going to each voice coil it wont hurt anything, they will just cancel each other out and you wont get any sound. But do be careful of the load the amplifier sees, some amps don’t like 2 ohm loads. Here is a good article that will explain everything you need to know about wiring DVC.
Must Read
http://www.adireaudio.com/tech_papers/dvc_wiring.htm
