All,
I have used apple TV + MiniDSP (and modified Behringer DCX 2496) to play my own music (Ripped CD collection), it worked yet it was not ideal and the cables where quite messy with a 3-way setup.
Now I am hooked on Spotify and fed up with Apple (and its dictatorial Itunes) and wanting to make my active set up wireless while in the Apple divorce process
The main idea is to use one Google Chromecast for each channel and:
1. Either, feed the digital source into a Minidsp on each side and into the active speaker.
2. Or, go simple using the DAC of the Chromecast and feed an analog channel into the (then bi-amped and analog filtered) speaker.
Option 1 is fairly simple I guess as the same output can be send to more Chromecast devices, the question is will they be perfectly synchronized? If not neither of the options will work
In take 2 it would be desirable if the AK4430 DAC in the Chromecaste could be used to process 1 channel only (double mono) as I am expecting a gain in sound quality if I can manage this, especially if a decent power supply is added to the mix.
Is anybody using a similar set-up and / or willing to think along on how to achieve this?
Peter
Peter
