Hi could someone tell me how to set up a Heathkit model 10-18 oscilloscope,so i can make sine,square wave and ac voltage checks . This is an old scope it has tube in it.
THANKS Dusk
THANKS Dusk
Heathkit Model 10-18 oscilloscope
Hi Janneman
What i want is how to use the Model 10-18 oscilloscope to read a ac sine wave from the output of my 100watt mosfet guitar amplifier. How do i do this?? Dusk
Hi Janneman
OK, there is a thread on this forum exactly for this. The thread name is like Textronix 22xx or 21xx you should be able to find it. Has several good text to do what you want.
janneman
BTW I think it is IO-18 rather than 10-18....
janneman
hEATHKIT MODEL 10-18
Hello Janneman
Thanks for the information i will look for the site on this form.
THANKS Dusk
Hello Janneman
THANKS Dusk
Hi Jannaman
Ifound the thread pointed out on oscilloscope and it may be what i need,also i saw the Heathkit model0-10 you spoke of ,but the unit i have is a later model mine has calibrated graticule. I do have a question . In the vertical channel it saids frequency response is +1db from 8 cps to 2.5mc and +1.5 to -5db from3cps to 5mc ,is this the bandwith of my unit ??
once again thanks very much for you help.
Dusk
Hi Jannaman
Dusk
2 Dusk:
yes, the bandwith is 3 cps (=Hertz, Hz) to 5 Mcps (= 5 MHz).
From 8 Hz t o2.5 Mhz signals the "error" in displaying is lower .
So it's just fine for most of the audio work. But keep in mind: This scope is old, needs proper warm-up time (appr. 30 minutes) and ofcourse is not as comfortable to use than newer ones (e.g. Tektronix 2215, etc.)
You might find some more info (schmeatic, handbook) at this site:
bama.sbc.edu
Look for heath because your model is a Hethkit scope.
Download is faster from bama.edebris.com.
hth.
bama.sbc.edu
hth.
- HOW to use a Heathkit Model 10-18 oscilloscope
