Here is the report that I did on the Pioneer PD77 similar, do use the Tent power supply as well as it was even better after I instaled that also down the track.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=60393
Cheers George
Cheers George
Hi Ingemar, in answer to your pm to me I have done work on the PD77 which I believe is similar if not the same as the PD75, your PD95 may be similar, so here goes, the Tentlabs XO3 using the XOsupply and the improved spidf output from the XO3 does wonders for the Pioneer as a transport,
If using as a player the XO2 will suffice with a XOsupply
The output can be improved by replacing the NE5532's with AD825's on dual Browndog convertor boards, remember the NE5532 is a dual opamp and the AD825 is a single smd, you have to use Browndog boards.
On the PD77 circuit you can see it's output is a dual fet driven by half of the NE5532 and it is driven from the other half I/V NE5532.
The output coupling cap C573 and C572 if the dc offset is now low (0v-10mv) because of the AD825's, you may short out as well to give direct coupled output.
Cheers George
Cheers George
Georgehifi is the right person that you should talk to.
A good clock, upgrade of the opamps to opa627 (which I preferred over the AD825) and the change of the couple output caps near the RCA output should be standard mods for your PD95.
Other basic mods includes biasing the opamps to run in Class A mode, change of caps etc...
There are a ton of mods that you can do on the PD95 but take it one step at a time.
Have fun
Have fun
Pd 95
Thank you George and Ruach .I have now changed the opamps in the analog output from jrc 2114 to opa 2604.What a huge differense it made,bas,treble everything is so much better.Have another question for you guys,where do i put my tent xo3 with supply,in the dac or in my drive?Have a Danish 1tech monsterdac that already has a Lc audio xo3 inside?
Kindly/Ingemar
Kindly/Ingemar
Re: Pd 95
In the transport, and then it will sing!
Cheers George
ingemar said:Thank you George and Ruach .I have now changed the opamps in the analog output from jrc 2114 to opa 2604.What a huge differense it made,bas,treble everything is so much better.Have another question for you guys,where do i put my tent xo3 with supply,in the dac or in my drive?Have a Danish 1tech monsterdac that already has a Lc audio xo3 inside?
Kindly/Ingemar
Cheers George
Pd95
Hi again.
I think i need some guidanse according mounting the xo3 clock,where do i connect the new spdif in/out so i can get the benefits of that?I want to bypass the old one so i dont need to make a new output.The same for the clock where do i connect it and what do i need to remove?
Kindly/Ingemar
Hi again.
Kindly/Ingemar
Re: pd 95
I noticed some here on ebay quite cheap i usually pay 40-50 complete. remember you will need two of these, one dual for each channel
http://cgi.ebay.com.au/ws/eBayISAPI...MEWA:IT&viewitem=&item=290056892110&rd=1&rd=1
Cheers George
ingemar said:Sorry its me again.
Forgot to ask you where i can find this as you calling it (browndog) and the AD 825Regards/Ingemar
Cheers George
Pd 95
Hi.
Shure i understand its hard for you guys to help me like this.
And i can ask sombody to do it for me,but i prefer to do it my self.I know that im not so skillfull that you guys are,but i can tell differense between parts and i understand to read a schematic and soldereing is no problem.Ive been reading the instructions on lc audios homepage and it says something like that i have to remove:X512 andR511 shortcut C517 and then connect clockout to pin3 on ic512 and use pin 7 for gnd the problem is that i cant find ic 512.
Have a nice weekend and thanks for your time/Ingemar
Hi.
- Digital Source
- How to upgrade a Pioneer Pd 95
