Hello,
for my multiroom project I want to split 7.1 HDMI channels into 4 stereo channels.
I use a pi 4 and a roline audio extractor. ROLINE HDMI 4K Audio Extraktor LPCM 7.1 - SECOMP GmbH
After "patching" the kernel I got 7.1 audio over HDMI. [Thanks to gordoste!] When I test it with:
I hear sound from every single speaker, even when aplay -l shows only 4 subdevices:
The last days I searched the whole web to find information about alsa and understand the configuration, but until now I`m not able understand it in detail.
So I hope, that someone could help me.
While I searched for information I have tested several configurations, for me this one looks very promising:
... but sadly I get no sound on any of the four stereo channels when I test it with:
Any help would be greatly appreciated.
Thanks in advance
Guido
Code:
speaker-test -c8 -t wave -D hw:0,0
Code:
aplay -l
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
Code:
pcm_slave.eightchannels {
pcm "hw:0,0"
channels 8
pcm.stereo1 {
type plug
slave.pcm {
type dshare
ipc_key 87882222
slave eightchannels
bindings [ 2 3 ]
pcm.stereo2 {
type plug
slave.pcm {
type dshare
ipc_key 87882222
slave eightchannels
bindings [ 4 5 ]
pcm.stereo3 {
type plug
slave.pcm {
type dshare
ipc_key 87882222
slave eightchannels
bindings [ 6 7 ]
pcm.stereo4 {
type plug
slave.pcm {
type dshare
ipc_key 87882222
slave eightchannels
bindings [ 0 1 ]
Code:
aplay -v -D stereo[1-4] /usr/share/sounds/alsa/Noise.wav
Thanks in advance
Guido
Maybe you could take a look at EQ APO. Rerouting of the 7.1 Surround Channels is implemented. With the Peace GUI it's no big deal.
peterwag: IIUC EQ APO is a windows application, it will not help in linux running on RPi.
turbur: Please post the verbose output of your final aplay command.
Hello phofman,
here is my aplay verbose output:
Thanks in adcance
Code:
aplay -v -D stereo1 /usr/share/sounds/alsa/Noise.wav
Playing WAVE '/usr/share/sounds/alsa/Noise.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Plug PCM: Route conversion PCM (sformat=S16_LE)
Transformation table:
0 <- 0
1 <- 0
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : S16_LE
subformat : STD
channels : 1
rate : 48000
exact rate : 48000 (48000/1)
msbits : 16
buffer_size : 6000
period_size : 3000
period_time : 62500
tstamp_mode : NONE
tstamp_type : MONOTONIC
period_step : 1
avail_min : 3000
period_event : 0
start_threshold : 6000
stop_threshold : 6000
silence_threshold: 0
silence_size : 0
boundary : 1572864000
Slave: Direct Share PCM
Its setup is:
stream : PLAYBACK
access : MMAP_INTERLEAVED
format : S16_LE
subformat : STD
channels : 2
rate : 48000
msbits : 16
buffer_size : 6000
period_size : 3000
period_time : 62500
tstamp_mode : NONE
period_step : 1
avail_min : 3000
period_event : 0
silence_size : 0
Hardware PCM card 0 'bcm2835 HDMI 1' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
format : S16_LE
subformat : STD
channels : 8
rate : 48000
msbits : 16
buffer_size : 8192
period_size : 3000
period_time : 62500
tstamp_mode : ENABLE
period_step : 1
avail_min : 3000
period_event : 0
start_threshold : 1
stop_threshold : 1073741824
silence_size : 1073741824
boundary : 1073741824
appl_ptr : 0
hw_ptr : 0
Thanks in adcance
In the devices stereoX you are binding only one channel. The documentation (here) says:
So I think you want the bindings:
HTH
bindings {
N INT # Slave channel INT for client channel N
Code:
stereo1:
bindings {
0 0
1 1
stereo2:
bindings {
0 2
1 3
etc.
HTH
