How to reduce PWM fan noise
Here's a little tip that might be usefull for somebody..
I installed 3 small fans in the chassis of my amp, just to blow a puff of fresh air in case things get hot.
I bought a cheap and cheerfull tehermal fan-speed controll of e-bay just to minimize fan-noise under normal operating conditions.
Turned out this fan controll used pulse-width modulation, something that would cause the fnas to buzz excessively at low speed, or even stop an buzz even more at low temperatures.
I just soldered a 220uF cap parallel to the fans, and this reduced the problem considerably by smoothing out the PWM signal at low frequencies, thereby feeding the fans low voltage DC current in stead of pulses that were too widely spaced to allow tha fans to run smoothly.
That looks like a good approach, that will take care of the whole PWM noise problem!
The downside is of course tha this circuit dosen't have any temperature controll. But perhaps replacing the pot with a temperature dependendt resistor will take care of that?
Those arctic fans look nice, but unfortunately too large for my particular application.
True, stalling of the fan can be a problem, but what about using a trim-pot and a thermal resistor together? The pot can be used for setting the minimum idle speed above stall, and then the thermal resistor can run the show from there on?
