How to modify electric fence Output?
1000V 1A Fuse, it looks like a 250V fuse. I will bet if you short the fence to ground you will not
blow the fuse. Even if you do blow the fuse it will arc over unless you use a 5500V rated fuse and then allow no protection,.
