Erm, can't find a good place to start. This was pulled from a junked Soundesign am/fm/tuner/phono unit. Need to figure out how to measure the different voltages that this transformer can provide..
Don't know which of the output wires to test, or in what combo..
The red and black will be mains in.
When testing an "unknown" its good practice to use a bulb in series with the primary to limit current if you made a mistake.
So you have 6 wires on the secondary. The green and blue look thicker then the others. These probably supplied the output stage etc
I would guess that these are a ?-0-? In other words a split centre tapped winding with blue as zero. So power it up and measure on AC volts between the blue and each green in turn.
The orange black and yellow ? Switch off and see if there is any electrical connection between these and the three just tested. Use meter on ohms. I'm guessing not.
So now power up again and measure AC volts between all combinations of these three wires and write them down. It should then hopefully make sense as too what it is.
very definitely good advice.When testing an "unknown" its good practice to use a bulb in series with the primary to limit current if you made a mistake.
I suggest you never direct power a mains project from the mains until after everything has been tested and proved to be correctly wired.
