How to measure the output impedance of the DAC chip
I'd like to know the output impedance of AK4393 DAC chip for correct filter and analog stage simulation.
It is a differential voltage output DAC.
How to measure this?
Also while at the subject what about current output DACs like PCM1704. How to determine their output impedance?
Regards,
Ergo
No, basicly I want the value of a resistor I should put in series with either a voltage or current source respectively in simulation...
I know that for an amp one could inject a sine wave of known voltage into the powered amps output through a known resistor and that way determine the output impedance.
I'm not sure if I can do it for DAC chip. Is it sure that I can't damage it? I do not know how they do the output circuit in component level inside the IC.
Ergo
