How to Measure ic 7WH04
Hi dears, I have a class D Behringer D1800, the ic 7WH04 may have a problem, when I turn the volume level to maximum it clips, and sometimes it clip without turning up the volume, with the ic in the board, I measured pin 3 with is a output signal and the ground, it measures 76 ohms, can this circuit be damaged?
I would like to know how to measure hex inverters properly. Thanks.
