How to integrate Baffle Step Compensation into existing discrete linestage?
Searching for solutions for a line level baffle step compensation I came across this:
As I don't want to fiddle with additionial opamps in the signal path, I wonder if it is possible to integrate something similar into my AMB α20 line stages:
Is it possible? And if, how?
You seem to need only some shelving low frequency boost (or shelving hi freq cut), correct? Your amplifier has global feedback, so the only two places I can see such filter being inserted is:
1.Input. A series resistor and cap network, paralelled with R2. It impacts input Z, which will fall to a few k above center frequency. For this reason, the signal source can change filter behaviour.
2.NFB network. A series resistor and cap network, paralelled with R14. Can mess stability if center frequency is high enough - do proper stability analysis.
Best regards,
Emerson
Correct!
Nah, won't do that. Input Z would be much too low for my uses.
Will try that tonight and report my findings.
Will check that with my o'scope.
More or less the same approach ... Thank you!
