You can't increase its basic sensitivity. But you can modify its radiation pattern with a waveguide so that the acoustic energy is redirected/concentrated in a particular direction. Also, one can increase a system's efficiency within a particular range by choosing an appropriate enclosure, for instance the low end of bass relfex enclosure vs a sealed enclosure.
Lastly, you can increase a system's voltage sensitivity by adding more drivers in parallel. For instance, TM vs MTM.
