how to identify fake transistors
I received a few quotes on the MJ15003 and MJ15004. One company (which supplies most of the components for our technikon) quoted about a third of the price of that of most companies.
I am concerned about buying fake transistors because the technikon aparently bought some fake products from them some time ago.
How do I chech a component to see if its fake (other that using a multimeter)
As a victim of fake transistors here are a couple of things to watch for:
If the price is "too good to be true" that's because it is.
If you have the means to easily measure Hfe, an unreasonably high figure (like 100++ ) from a power transistor is a sign something is not right. Mine had a tiny chip that was probably intended for a low voltage, small signal transistor.
If you have a known good copy of the transistor, beware of version where the printed label looks different. Sometimes the fakes actually have better quality printing on them than the original.
It would be a good idea to request a sample of each and measure Hfe and B-E, B-C zero-bias capacitances
Hfe should not be too far from the figures quoted on the datasheet, but if the dies are fakes taken from other smaller power transistors then their Hfe value will be in the correct range and won't be useful for fake detection
Zero-bias junction capacitance values are very useful in determining die sizes. Each model of transistor shows typical capacitance values. Fake transistors tend to have 1/2 to 1/10 of expected capacitances due to smaller die sizes. Capacitance is roughly proportional to die area
You may post measured capacitance values on the forum, asking for other people to compare them to the ones measured on devices known to be genuine. Fakes will allways show smaller capacitances
