Hello!
I'm currently breadboarding a guitaramplifier, sort of like a fender Combo clone...
My goal with this project is to have a nice amplifier with a good Clean sound, but yet having a nice Crunch / fuzz when I crank it to Overdrive.
So far I have got a very nice clean sound. But alas, the fuzz is lacking! I DO get some fuzz when I crank it, but this is not very dynamic, mostly being slappy and flat and boring. I think maybe I have too little gain to get a good cranked tone...
So, I was wondering, does anyone know how to get good warm fuzz in a tubeamp? My setup is pretty much like a Fender Pro Amp Blackface... 12AX7 --> Tone controls (~22dB loss) --> 12AX7 (2V bias) -->12AT7 phase splitter --> Output stage.
I've read somewhere that it is beneficial to have some sort of LP filters to filter out the high order harmonics to soften the fuzz, but my atempts with this have not been succesfull...
Maybe I would need another 12AX7 stage after the tone controls to add more gain an thus more Overdrive into the following 12AX7? Maybe a pentode?
Thing is, I don't really know how fuzz / distortion / Overdrive is generated in guitar amps, I just presume one drives a tube into clipping.
I've been studying tons of old and new guitar amp schematics, and though there is allot of similarity between many, there is just so many variations from a simple Fender circuit to a complex Mesa Boogie preamp, that my head spinns around and I don't know where to begin to expereiment to make my amp distort really nice.
So, I hope someone has experience on this subject.
I could post a message at, say, AMPAGE, but my experience from previous posts there is that there are not many "tech's" that really are DIY tube gurus that can aswer the above questions, but rather musichans that happens to know a little about tubes... No offence to anyone of course.
if i rember corectly putting a diode in the feed back loop is how many comerciall units produce the distortion
Lots of ways... the usual, old-school is simply by cascading gain stages. Usually 2 or 3 will give you a decent overdrive crunch with enough guitar level. You might want to try looking for "classic" tube amp schematics to see how these gain stages are interconeccted (some use voltage dividers, weird cap values to shape the sound, etc), but in a nutshell it's how it works.
As mentioned, diodes in the feedback loop do the trick too, through it's a different sound. Try two diodes in parallel, back to back. Using one regular Si diode and one Ge diode works better as the clipping becomes asymetrical (which is more like tube clipping, yet not completely there 🙂 )
Several possibilities. I am assuming we are not talking about a channel switching setup, just a single channel.
Phase 1:
- Increase the NFB resistor or eliminate altogether.
- Change phase splitter tube to 12AX7.
- Experiment with different values of tail resistor up to 47k. Increasing the tail resistor lowers the headroom of the phase splitter.
- Install a master volume control. use the type with the ganged pot after the phase splitter.
- Reduce the value of the preamp cathode bypass caps to 1-10uf. You want to cut bass response or else the overdriven sound will get muddy. Reduce interstage coupling caps to as small as possible. too small = no bass. too big = blocking distortion. try different caps and listen.
Phase 2:
- change the preamp to resemble the Fender AB763 reverb channel, basically adding one more gain stage. Reduce the value of the 3.3Meg interstage resistor for more gain.
- Wire the EL34 in triode mode.
- Run the EL34 in cathode bias.
I'd start with the phase 1 mods. I like about 6-10 db negative feedback. This should give you more crunch while still retaining the classic Fenderish "gling" clean tone. You can dial in the crunch with the guitar's volume contol.
Triode mode and/or cathode bias gives a softer, more compressed overdriven sound. some like it, some don't.
There are a zillion other preamp configurations, but if you want to preserve the clean tone, its hard to beat the Fender style preamp.
You can try diodes if you are after a buzzier type of sound. I don't like that sound myself. I like Fenderish clean with a bit of AC/DC - Early Led Zeppelin crunch based on picking dynamics and the guitar's volume setting.
Phase 1:
Phase 2:
I've been there too. Trying to get some nice overdrive/fuzz from a Fender non-reverb clone. I didn't succeed. I think you really need a Fender reverb schematic. The extra gain stage will do the trick. Personnaly I really like the newer Fender Blues Junior, so I copied that schematic. You could try that too. My absolute favorite is the soldano/Mesa Boogie (very simmilar) type of circuit! Really nice articulate distortion!
goodluck,
Thijs
PS
A Proco RAT clone will do the trick very nicely too! Cheap and bood sound, but no tubes.
goodluck,
Thijs
PS
Wow, Thanks for all the input!!
I'll first say a little about my current setup, I've bredboarded.
I have no NFB, as this was the first thing I experimented with, I really liked the sound better without. More punch and slightly clearer, and the Tonestack seemed to "work" better also...
About the tonestack, I'm not using the "fender style" tonestack. I used Tonestack Calculator from Duncanamps and put in the values and saw that the response was very... rollercouster 🙂 This led me to the descision to use a "Orange style" (or James as it is called in the TSC. A little tougher load for the tube to drive, but very presice adjustments of Bass and Treble.
This lead me to another experiment, I tried an active load for the first pre-amp tube driving the tonestack, namly a C4S, a Constant Current Source. I Had some suitable Transistors laying around so I thought I'd try it. I'm not really afraid of mixing Tubes and trans. when it comes to guitaramps...
well, I liked the results very much! More gain and the Tonestack adjustibles responded very much better than with a 100k plate resistor. The CCS makes the triode work at maximum gain, and the impedance driving the tonestack will be much lower.
I set the current at 1.33mA, just as in the schematic. Due to the Constant aspect of my Current Source, I also omitted the Bypass cap in this stage.
One other thing is that of the 0.001uF cap at the phasesplitter input, At first I just used a 0.01 cap, in good belief that it was a 0.001uF. Then I discovered the obious wrong value and replaced, and I suddenly realised how much 1 cap can alternate the sound! got rid of allot of "grumph" and "mud" in the lower regions, even got ridd of some hum!
A master volume was implemented from the begining in the form of a dual 220k log pot instead of the 220k grid resistors of the EL34's. No problems with this so far.
So now I'll try the different tips from you guys and report back later. Think I'll try the simple diodes first, but I really want that Tube crunch! (being a tube-amp and all...🙂
I like that good ol' Zeppelin / Stones crunch! (the rythm guitar on "Bitch" in particular!)
I took a look at the AB763 Reverb amp, and the 10pF / 3.3M combo seems to be the trick, I'll definently try that, I've not seen thatone around in many amps, but I remeber seeing it in a VOX amp and wondering what it did. Though the 3.3M will give ALLOT of attunation I think, so I'll experiment...
One question; Is it best to have a preamp tube to distort, or having the Phasesplitter distort?
About getting rid of the 12AT7, is there any particullar reason for this? I really like the idea of having an non 'AX7 in the chain...
I never liked the sound of a clipping phasespliter, be it split-load or long tialed pair. But it is not standart to make your phasesplitter go into clipping before your output valve do... except if you have a MV after the phaseplitter...
I also like preamp-overdrive better than output overdrive, much much much too loud 😱
gr,
thijs
gr,
thijs
Hmmm, just peeked at the Blus Jr. schematic...
As I understand it, the Overdrive is generated BEFORE the Tonestack, controlled by a Volume pot, and then after the tonestack, there is a tubestage with a mastervolume controll...
What's that FET doing at the cathode of the first stage?
The FET is used to short an 22uF capacitor to ground. That way the cathode bias resistor is shorted by a capacitor: increasing gain. This can be done by a footswitch.
The topology is of the amp is in essence:
Gain stage ->
volume(some High Pass) ->
Gain stage ->
tone stack ->
Gain stage with Low Pass and volume control
Even when the first volume controll is all the way up, the second gain stage hardly or never clips partly due to the 130KOhm. I think the clipping comes from the third gain stage. The LowPass filter is very importand too!
Typical fenderisch is the tone stack BEFORE the clipping stage, but they needed some controll over the harsch clipping, so there's the Low pass just before the master volume controll.
gr,
Thijs
Gain stage ->
Gain stage ->
tone stack ->
gr,
Thijs
Hmmm, yeah, okay.
But, my calculations will give me, for the LP filter right before the Mastervolume; with the 430k and the 1500pF, a -3db point at 247Hz! There must be something I am overlooking.
At what frequincy would it be wise to have such a LP filter at? 10kHz? 5kHz? 20kHz?
and the Highpass filtereing with the 0.0022uF and the 430k and the 50k pot gives a knee around 150Hz am i right?
I suddenly realised that EL84's are used here, and that's the reason for all the attunation after the gainstages...
thanks,
Stigla
thanks,
Stigla
Ehhhhhhhh .. hmmmmmm 🙄 something like
1 / 2*pi*RC ehhhhhhhhh where's that spice simulator again?
I guess about 246.75Hz That sound a little low, about 1KHz seems more likely.. hmmm I never really calculated the values before ... maybe we should consider R40 and R41 in parrallel so the resistance the 1500pF sees is about 50K, that would give 2.5KHz for F-3?
but usually around 500 to 1KHz works for me..around 1KHz you can get a irritating, very prominent harsch sound.. you should put some of your favorite guitar sound through your MP3 player and mesh around with your EQ... very instructive!
You are right about the EL84 needing only about 10Vrms but the reason for the attenuation is not to keep the output stage from clipping, but to keep the phasesplitter from clipping, well I think.
The attenuation at the first volume controll is part of the High Pass structure, needed to avoid mushy overdrive.
goodluck,
Thijs
PS Do try a Proco RAT type of pedal, it might be just what you need, for 15$ you can build one!
goodluck,
Thijs
I recommended the 12AX7 phase splitter for more gain with a 2 stage preamp. The classic Marshalls and Voxes used an AX7. The AT7 has much lower plate resistance and better drive capability, but that's not necessarily what you want in a crunchy guitar amp.
The CCS on the first stage looks like an interesting idea. I've never tried that, but I have used an IRF820 MOSFET wired as a source follower immediately following the first gain stage. This drives the tone stack with a much lower source impedance. Works great and very easy to implement.
The James tone stack looks good on paper, but I've always preferred the "rollercoaster" Fender/Marshall/Vox type tone stack.
In the classic "poweramp" distortion of the 1960's and early 70's, the output, phase splitter, and sometimes even the latter part of the preamp are all clipping. The problem is that with a pair of EL34 at 450v, you need to crank it to ear-bleeding volume to get that tone. Some people report good results using attenuators such as a Hot Plate or Power Brake. Not my cup of tea, but it may work for you. Try wiring the EL34s in triode mode. It will cut the output power from a nominal 50 watts to around 20 watts. I've had good results with this in my twin reverb, your mileage may vary.
If you go with the AB763 reverb channel, try reducing the 3.3Meg to 1Meg and a 470k grid resistor on the 3rd stage. I usually eliminate the 10pf cap in this case. Crunch City! You'll want to attenuate the signal after the 3rd stage so it doesn't hit the phase splitter too hard.
If you need a LP filter, take a look at the Vox AC30 "cut" control. This can tame an overly bright preamp and is adjustable for different guitars.
I like the Blues Junior too. A lot of its appeal to me is the glorious EL84 output tubes, lower B+ voltage, lower output power and 33k tail resistor (low headroom phase splitter). The reverb circuit is a bit weak though. By the way I simulated the 3rd preamp stage and LP filter section in CircuitMaker and came out with a -3db point of 3.74k.
Regards,
Mike
Regards,
Mike
-3db point of 3.74kHz ??? Great.. now I feel pretty stupid
About that Junior schematic.. can you calculate what stage will clip first? Your comment about the low headroom Phasesplitter interests me! Maybe the Blues Junior uses phaseplitter clipping?
I once simulated the whole circuit and found out that the 3rd gain stage provided the clipping, but I might have gone wrong somewhere...
gr,
Thijs
gr,
Thijs
Hello!
Last night I tried some of the ideas on my breadboard.
The diodes was the first ones out, and since I had no feedback, I put them in between the phasesplitter and the last preamptube.
I used 2 diodes, back 2 back, Si types. Wow, fuzz from the beginning of! Rectification city! 🙂 It reminded me of my old Peavy Bandit 12... Hmmm, I then tried to add another tubestage, like in the Super Reverb. (removing the diodes...)
Hmmm, I wonder what it would sound like, if I used TUBE diodes... Well, anyway;
I first tried a 50/50 splitt of the gain, 2 470k in series, and the grid in the middle, with no cap over the "top" resistor. Yep, distortion is present, when I crank it! Sounded like a Crate, really thight and "heavy" kind of distortion. Not necceserily what I want. Increasing the Top resistor to a 2,2M gave me a nice transition from no fuzz to really nice "vintage" up to a thighter but not so heavy one at max volume. Though, still a bit harsh and a little muddy in the lows, but filters will help this I think.
Adding a cap in parallel with the 2,2M caused serious oscillation, with any value, (well, any reasonable value...) so I abandoned this, gridstoppers didn't help.
I also tried a ECC82, with the intend of having less gain, and thus needeing less attunation, but this was no luck, I liked the 'AX7 better. Heck, I even tried a 9002 (mu of 25), but I still fancy that nice transition of the 'ax7 from no to full crunch.
But I think I'll give the 9002 another try... just for fun. If using a 12AX7 I will have 1 unsued section... The 9002 is a single triode on a 7-pin base 🙄
One potantial problem I see is all the noise I got from adding that extra stage... I had the Volume before the extra stage, and so when the mastervolume at 12'o clock, the noise was very high. Even with a 2,2M to 470k attunation and the preamp volume at MIN.
Today I will try various filters and try to tame the crunch a bit. Any suggestions as of how I can implement a LP filter. My circuit looks now allot like the Super-Reverb.
I'm considdering to have a switching option to add that extra stage to get crusch, and when I don't want it, I can just bypass it...
Anyway my intent is still to have 2 channels, like in the Super-reverb, One Normal, and one Tremolo / clean / crunch channel.
The only AC30 schematic I've got is a bit messy, so I cant find any "cut" controll... BTW, the phasesplitter in that amp seems to have a small headroom, with a 33k and a 7,5k tail resistor... Hmmm.... maybe the AC30 uses phasesplitter overdrive? I think so, if we considder that it have only one stage in front! If this amp distort at all, I have never had the luck to hear one... Live that is, didn't the Beatles use thisone allot?
Boy, this is great fun!!
Thanks for all the help guys!
Happy new year!
Stigla
Happy new year!
Stigla
Thijs said:
-3db point of 3.74kHz ??? Great.. now I feel pretty stupid ...
Don't feel bad. This is more complex than it looks. You have to account for the tube's anode resistance, 100k plate resistor, coupling cap, and 50k pot in addition to the 430k/1500pf.
This depends on the setting of the master volume control. If it is cranked all the way up, then most likely the output stage will clip first then the splitter then the 3rd stage. If the master is turned down then the 3rd stage will definitely clip first. So the Junior can dial in the "classic" poweramp distortion and/or preamp distortion. I think that is part of the reason why it has been a very successful amp for Fender in spite of the less-than-inspiring reverb circuit. Plus EL84s sound great, you really have to go out of your way to build a lousy sounding EL84 amp. EL84s sound great in hi-fi amps too.
This is based on the concept of preventing "blocking distortion" which sounds like garbage. An excellent explanation of this can be found here:
www.aikenamps.com under the tech info - advanced section
Here, Aiken advises adjusting the phase splitter so it clips at about the same time as the output stage. He advocates series resistances, but another way is to increase the tail resistor for less headroom in the splitter. The advice about lowering the coupling caps and grid resistors is excellent too.
Regards,
Mike
Regards,
Mike
Vox made some beautiful, great sounding amps, but their schematics are a mess, as are the insides of old AC30s.
The cut control is located after the phase splitter coupling caps. It consists of a 250k audio pot in series with a 0.0047uf cap.
See http://www1.korksoft.com/~schem/voxamps/ac301960.pdf
The Beatles did use an AC30 for their earlier stuff. A classic example is "I Feel Fine." Totally delicious guitar tone
Not good. Probably a lead dress issue. or a grounding issue. These kind of problems can be a real beast.
OK, since you've added a 3rd preamp gain stage, it's time to reconsider adding some negative feedback. It will make a lot of that noise go bye-bye. Also will give you an excuse to add a presense control. by the way, how much attenuation do you have between the 3rd stage and the splitter?
Regards,
Mike
Regards,
Mike
Currently, I've got a 100k/270k attunation, due to my recent Clean channel experemintation. In fact, I had forgot all about it... The real load should be 220k/50k or something. (Tremolo pot)
Guess this will attunate the noise too.... I'll also try to add feedback. Hmmm, presense control... I'll see into that as well. I do find the sound to be a little on the dark side.
Heh, funny how it all works out... My first thoughts about building an Guitaramp; "I'll make it simple, yeah, real simple..." 🙂
Stigla
No, thats wrong... Wooops! I dont have any attunation in the Vibrato channel... the last tube just drives the 50k Tremolo pot, and then theres a 220k'er and straight into the phasespliter... Though, I belive maybe I have to take the input impedance of the phasesplitter and the output impedance of the "normal" channel into account, yes?The real load should be 220k/50k or something. (Tremolo pot)
About a lopass filter: What if I add a large griddstopper at the grid of the 3'rd tube, say, 100k to 330k or something, I would then get a LP filter with the input capacitance... Or do the LP filterering have to be AFTER the tube? (filtering the actual crunch, and not just the frequencies hitting the distorting tube?)
regards,
stig
- Live Sound
- Instruments and Amps
- How to get good Fuzz from a Guitar-amp project.
