While I‘d agree that digital eualizing isn‘t perfect at least theoretically I get excellent results sonically espacialley in the lower freq. region.DF mentioned equalizing vinyl with digital (for no phase shifts), which absolutely removes the whole vinyl idea from the equation.
And I don‘t think doing it digitally is devils deed per se, because apart from being puritan one might seek the best quality for a case, for instance when a master tape is lost or destroyed, and your best reference is an early vinyl copy which betters later editions made from obscure sources.
You get excellent results but you aren't listening to vinyl.
Instead, as an alternative, you can listen to the original master transfer to digital.
Still, I don't know any phono which has perfect phase.
Huh?
Believe me, i would if i could...Instead, as an alternative, you can listen to the original master transfer to digital.
An electrical filter will do nothing to reduce the modulation of the signal by subsonics. You need mechanical damping.From what I have read in the article mentioned, it is desirable to insert a sonic filter (36 dB per octave like that of Rod Elliot) so that the subsonic frequencies do not interfere or modulate the audible frequencies. It is still not clear to me what influences the phase curve in an RIAA design.
All cartridge/tonearm setups form a resonant system. Frequency affects audibility and damping affects level. Resonances between 4 and 10Hz are most audible, so 12Hz fundamental resonance (in theory) is a good place to be then you can add damping.From a poorly chosen and poorly damped arm-cartridge resonance. It gets excited by warps and to a lesser degree by off-centredness. I prefer dealing with the resonance mechanically, rather than having a silly filter.
technically digital could be a better RIAA eq as a brick wall filter at 19hz cuts all subsonic frequencies. it would have to be at least 24 bit 96 khz to silence the crowd that claim to hear quantization artifacts on CD.
s /n should be better as well. sound quality as percieved may sound "dead" as it produces a perfect RIAA eq based on a perfect cartridge input.
That's the way I'm heading, at least for MC. Seems a more sensible solution all around to let the DSP take the strain 🙂
I understand the concept, but how do I reduce the subsonic produced by the ripple of the vinyl. Even if it's imperceptible, it wobbles on the woofer.
Firstly you carefully select arm and cartridge resonance, then you make sure records are centred properly, then you damp the resonance, like the townsend rock, SME arms, well tempered, ET-2 etc with their damping troughs. Classic Duals had a damped counterweight. There were also electrically damped arms. Not seen measurements as to how effective they were.
YouTube
Thanks for showing the video.
I did not know that the brush is to dampen low frequency oscillations.
I have a magnetic capsule that I do not use because it is old that it has the brush.
It is a Pickering V15 but very old and spherical diamond.
I am using AT 440 Mlb.
overload on a phono preamp is a non issue. Mine is set to put out 8v p-p of a possible 40 volts p-p. Scoping the output , loud pops clicks and scratches are seen at less then 5v p-p max.
I did install a 40khz hi pass filter but that should not reduce noise pops by much.
tube preamps have 100+ volts of p-p capability.
If it moves the woofer visibly on ALL your vinyl there is a big issue with the tonearm/cartridge
Some of the wrapped vinyl should produce that woofer sub-sonic which is ok and can be alleviated with an outer ring weight + center clamp.
I would say here about 10% of the vinyl I have has this issue of sub-sonics, which is annoying, better turn off the sub-woofer. But it doesn't sound bad for this reason because the system has plenty of power as well as the speakers.
To ALPUY’s OP: it’s important to recognize that there is dynamics in electrical sense (which is well defined and measurable) and perceived dynamics which is subject of psychoacoustic. While there is no significant difference in measurable dynamic (in electrical sense) among the modern preamps, as a result of certain psychoacoustic phenomena, some minor imperfection (e.g. small deviation in the frequency response, certain forms of harmonic distortions, etc.) could result in perceived reduction of dynamic (which is purely subjective). This relation isn’t well explored AFAIK. So there is no clear answer which micro-imperfections have most impact to perceived dynamics (otherwise, all reasonable manufacturers will follow the right recipe and there will be no discrepancy in perceived dynamics among preamps on the market). The only way is to eliminate potential culprits one by one until desired quality is achieved. That’s experience.
Agreed. Electronics can peak limit by clipping but compression needs the electronics to change gain depending on the envelope. This requires longer time constants. This dosnt happen accidentally or as a side effect.
You could still cause overload in the input section, or slew rate limiting.
Convincing answer
It is the answer in which I totally agree after analyzing it.
Don't give up getting good 'dynamic' sound from vinyl. I just plug back the 100 Watt amplifier on my system and it shows dramatic difference between vinyl and cd/flac streams from 'hifi' dacs.
It might sound disconcerting to you but the phono stages are weak points and have problems but the little details like the tone arm and platter makes an incredibly big difference in sound and the tt makes knows it.
They charge ridiculous premiums to customers to attain a sound which should not cost so much. the difference with a 200$ tt and a 5000 one is not so much in material but the research and exclusivity. Tight manufacturing specifications and new materials such as carbon fiber makes the good sound of the turn table possible and the greatest advance in technology of audio imo.
Seriously? I have a 38 year old tonarm that used carbon fibre. They could grind things to silly tolerances in the early 70s. I would argue that record replay technology has gone backwards rather than forwards. No advances I can see in last 40 years.
- Analogue Source
- How to get good dynamics in phono stage
