how to gain voltage in a rectifier tube based PSU
Hi gentlemen, A friend of mine, ask to add some power in a single anded tube Amplifier, I tell him that it is possible to gain the power doubling the voltage of the PSU.
To rise about 8, 10 Watt I need About 400V that's quite standard.
the main problem is that he want to use the rectifier tube, this condition make this task mutch more complicate. so I make first schematic that works
but it rise the voltage of about 3 times the starting one: 700V.
Ok I will put a Zener back biased in the central tap of the tranformer to produce and control the drop to get my 400V, it works, but we totaly loose the softstart action of the rectifier tube, so I elaborate something that i never seen before.. ( nether the preview acqualy )
and I'm not able to understend if this can works, maby the capacitors before the anodes can hurt the tube for a reason that I really do not know, or the concept is wrong at the begin , I need the help of someone skilled then me.
maby there is a simpler way.. I do not kow
comments please
thank you
MiK.
With due respect, do the things the right way.
You want to keep the tube rectifier?
Ok, your choice, then I would simply get a new power transformer with suitably higher voltage secondaries, and of course higher VA rating.
Do not apply a kludge which brings new problems, which wil be "solved" by another kludge which will bring newer problems, which wil be .....
I think this is the best way to get more out of the supply and keep the warm-up delay of the tube.
Originaly the voltage was arond 300V, like this you get 350V.
Mona
