The tuning indicator on my Nikko NA-550 is stuck. Spinning the weighted knob does the job but the indicator does not move at all so there must be a broken wire or a disconnect somewhere.
Most common fix?
Thank You!
Most common fix?
Thank You!
It's a simple mechanical arrangement. Take off the cover and look at it. If it's the usual pointer that doesn't move, it's slipping on the cord. A dab of glue or pinch of the clip will do it.
