How to 'fine tune' your amps?
The real issue with the Williamson is not so much the number of rolloffs, but their ratios. To stabilize the circuit, the dominant rolloffs have to be spaced more widely from the remainder.
Yes. that is one way of doing it but it is difficult with that many poles, a better way is to use a phase correction network for low freqencies, then you achieve a completely stable circuit and with higher open loop gain = higher degree of feedback down to very low frequencies. Look at the simulations I linked to in my earlier post.
Maybe it should also be mentioned that the original Williamson is not unstable and doesn't oscillate but it has only about 30deg phase margin for low frequencies, this is precisely on the margin for stability according to what Bode wote.
Regards Hans
