How to find driver specs of a commercial subwoofer
Hello,
I’m currently trying to build new subwoofer enclosure from a Mosscade Titan 7.3 that I have recently acquired. The enclosure of the Titan 7.3 is unfortunately cracked in a few different places from the poor care of its previous owner. Unfortunately I cannot find the necessary specs of the driver to be able to design the enclosure on WinISD. Does anyone have an idea where I could find such information or have an alternative solution to bypass this problem? Thank you.
Yes, thank you. The problem is I do not have the equipment to measure the stats myself and as I am on a tight budget I am trying to find solutions that won’t augment the cost. I’ve also thought about just using the same dimensions, but the Titan 7.3 has a passive radiator. As this is a learning project for me I wanted to experience making a slot port enclosure, so the dimensions will be different.
