How to earth my amplifier
In my new amp I have connected the safety earth directly to signal ground at the RCA inputs. Although there is no hum whatsoever, I can still here a difference in sound.
With the connection in place single instruments seem to have a 'aura' around them. At first it sounds like ambient detail, but when the connection is removed, everything sounds more pure and more quiet.
I don't worry much over safety ground, but it's always nice to have it. Further, I can't really decide what sounds best. My speaker do not have enough resolution to know if the aura is part of the signal or some sort of distortion. However, I feel that no connection between safety and signal ground must be better for sound. I can't see any benefits from this other than meeting safety regulations.
Does anyone have similar experiences?
Keep chassis earth (mains safety earth) and power supply + signal earth seperated via a loop breaker, as Rod Elliot shows on his websites - basically this means connecting the two togethr via 2 inverse parallel diodes, a 10R 5W, and a 100nF capacitor (all in parallel)
OK, I've listened some more and now its clear. The sound is better when there is no connection between earth and signal ground.
Once you put your finger on it, the difference becomes very clear and is suddenly not so subtle anymore: all instruments seem more real, alive and better placed within the soundstage.
So, grounding is not only important for hum problems. I wonder how many people don't realise that they have a problem.
Well, perhaps its not really a problem then, is it?
You are right, the system sounds better when everything is "floating" with no ground connection.
The other thing to check is to make sure that the AC mains power is correctly oriented to each component. Do this one component at time, with *nothing* else connected to it. Try the AC mains in both orientations and measure the AC voltage between the chassis and the safety ground in the wall receptacle. The orientation with the lower voltage is the correct orientiation. This is actually a leakage current on the chassis due to the capacitance between the primary winding of the power transformer and the chassis. The transformer is never perfectly symmetric, so one orientation is better.
If you do both of these things, the sound is significantly better.
Next you will find that if a "cheater" plug is required to float the ground (true in most cases) that this also degrades the sound slightly. Presumably this is due to the extra contacts in the AC power path. Removing the ground pin from the AC power cord is the easiest way to avoid using a cheater plug.
I know this may sound silly but do you think that the voltage in each country makes an amplifers sound different?
Some people say the voltage in London is very bad for hi-fi and there hi-fi sound better in other parts of the country?
Is this just wishful thinking or is there something to this?
Everything makes a difference.
I know in the UK that many places have very high voltage. The EC normalized at 230 VAC, *except* for the UK. They stubbornly stuck with 240 VAC, which they call 230 VAC +/- 6% (the EC limit). However, in many areas the voltage will rise as high as 255 - 260 VAC at times. It's not hard to imagine this causing sonic problems with at least some equipment.
On a separate yet related topic, large industrial cities (London, NYC, Los Angeles, etc.) tend to have "noisier" power than other areas. This will also have a deleterious effect on sound quality. Usually the sound quality will be better late at night, presumably because there is less noise on the AC mains.
Actually, I'm rather surprised you have this problem at all....
Unless you have the amp(s) plugged into a wall outlet that sports an earthed mains connection, that is.
In Europe, I assume you do live in the Netherlands, these earthed mains outlets are often only found in areas such as the kitchen and other dedicated places where washing machines, deepfreezers and such are in installed.
In short, you won't easily find three pronged outlets in an ordinary living room in Western European houses.
Your description of the effect is pretty accurate, it often sounds better without the Earth link connected to ground.
Oh, in case you follow Charles H's excellent advise on checking mains polarity: mark your plugs for correct polarity once you're sure you have found the correct way around.
It does pay of and it only takes a little of your time...once.
Yeah...I heard that before and witnessed it myself...I used to live in a big city (Brussels and Munich) and often found myself enjoying the music only way past midnight when there's alot less pollution on the grid going on.
There's ofcourse alot less background noise which also helps...
Much to my dismay, mains filters (the ones I tried anyway) didn't even improve things for me, quite to the contrary really.
I live in a small city now with hardly any industrial activity to speak of and my system sounds good most of the time, most of the day.
Not always but it's much, much better than before.
Start saving up....🙂
Cheers, 😉
I have heard that it sounded "foggy" or "rainy" in London.
I have never thought of NYC as an "industrial city". there just aren't so many factories here anymore.
I've used the Self method of a star ground. Power gnd, signal common and PS common all meet at one off PCB point. Then the signal input shield is tied to the chasis earth point. The chsis earth point goes to the power entry. I found this conceptually worrisome at first, but it works - no hum, no hiss, no aura, no nothing just dark, cold silence. The only caveat is with regard to saftey - be sure the shield can take the worst case current.
Well,
The power outlet does indeed not have a earth connection, but the mains extension does. So there can be groundconnections between other gear.
I think that my tuner may be earthed through its cable antenna (you get that?). That may cause the problem.
Charles,
About your advice: I tried that once but it didn't work. Say that I measure my power amp first. I put in the right orientation. Then I proceed with other equipment. When, after all equipment is in the right orientation, I measure the power amp again. To my surprise it must now be connected in the other orientation..
OOps, I just saw that one has to disconnect all other connections, I suppose it will work, sorry!
OK,
I just tried a loop breaker (after RODE's recipe) with on one side both signal ground (L/R) and on the other side chassis and safety ground.
It made quite some improvement. I still prefer the sound without the safety ground attached. Although the breaker takes away 90% of the problem.
I guess that's the solution then: no loop and hence no loop-breaker. If you don't hear from me again, assume I electrocuted myself for the good of superior audio😉
Question for Mr. Hansen
I sometimes hear that a connection between the case and signal ground helps for amp stability. OTOH, some say that chassis earthing helps prevent EMI. So, what's better?
Connect all grounds to chassis and no earthing
or
Earth case and no electrical connections between case and circuitry whatsoever?
You're best off without earth ground but with the chassis firmly attached to the circuit ground. Usually bolting the rca connectors straight onto the chassis works best for this purpose. The only disadvantage is that the floating circuit ground is now externalised as the chassis ground.
The ideal concept for combining a floating circuit ground and an earth ground is by putting all the circuitry inside a sub-chassis (ie to provide something similar to the above situation) and mounting that -fully insulated- inside the actual equipment box. The latter can then be connected to earth ground.
Personally I stick to balanced connections wherever I can, because it's the only way of preventing rubbish from the mains coming in whenever more than two pieces of equipment are interconnected. Most equipment has capacitors (called Y capacitors) somewhere from the mains going to the chassis as part of a mains filter, in a mistaken attempt to get a cleaner power supply.
The power supply may be cleaner but the ground surely is clean no more!
One such device in an audio system subtly degrades sound quality. Two such devices wreck it. Cables start sounding different depending on the resistance of the shield (rca ground contact). Correctly conceived balanced connections avoid these problems but are badly understood - so badly in effect that many people add unnecessary circuitry but fail to make them work.
A lot of current can be riding on those "yellow" wires you have from the gnd of the RCA's to the Earth/gnd connection of your AC socket.
I'd suggest using a 100 ohm resistance to isolate heavy current leaks. It will still be enough to form a non-floating ground for the amp's input stages albeit avoid the high current passing through it. This should cause reduction in audible hum.
K-
