Hello everybody,
I have an Eve Audio subwoofer in my home studio with an amplifier that died on me years ago. I have recently made the decision to order a new plate amp and retrofit that into the cabinet. (https://www.aliexpress.com/i/1005005492071000.html)
The amp only provides a single channel output instead of stereo, therefore I'll need to connect both my mains and the subwoofer to the soundcard requiring a total of four outputs.
So my question is: Do I require an active splitter kind of device or can I get away with a pair of Y cables?
(I am using multiple eq's for room correction etc. so I don't worry about the absence of a crossover)
Just Y cables should work fine.
thank you for your reply, so no problem regarding the impedance and what not?
