How to determine ripple voltage?
From http://sound.westhost.com/power-supplies.htm
The required capacitance for a given load current and ripple voltage is determined (approximately) by the formula [1]...
C = ( I L / ΔV) * k * 1,000 uF ... where
I L = Load current
ΔV = peak-peak ripple voltage
k = 6 for 120Hz or 7 for 100Hz ripple frequency
Load current is covered, though I can't find anything on peak-peak ripple voltage. What number plugs in here?
Chip amp for a 5.1 application: 5 LM3886s at 4ohms (28v rails seems to be the suggestion from NSC on their LM3886 page for 4ohm use) connected to a home theater PC.
The current debate raging in my head is whether or not to DIY the subwoofer amplifier and include it in the same box, or if I should use a commercially available plate amp. Either way, the sub wants a considerable amount of juice.
