How to cut my sub out of my system with a switch?
I'm using a powered Acoustic Profiles sub which is hooked up in between my amp and speakers, it sounds a treat... But I'm moving into an apartment from a house and I'm worried about booming sub volume during movies disturbing my neighbours.
I'm looking for a way to cut the sub out of my system when I'm watching movies or at night. Anybody DIY'd some kind of switch box for this (or found a cheap off the shelf solution)
Just as KathieandDad said:
Usually, a powered sub just taps some of the speaker-level signal, processes it via a low-pass filter and then amplifies it for the sub.
What goes in speaker-level usually comes out speaker-level, with no filtering in between.
Concerning the switch: Use a switched extension cord or even a (wireless) switched receptacle for convenience. Usually available at any supermarket with an electronics department, or hardware store.
Andreas
EDIT: Corner placement for a sub is far from optimal, unless it is designed for that or one likes over-present, wobbly bass.
disaster area, have you set an hpf for your mains on your receiver? or another x over in your system?
so your trying to turn off your subwoofer remotely, and then have your speakers reproduce the bass simultaneously? if you haven't set any active x-overs, those woofers are already reproducing those frequencies.
