I am using the Audio Codec IC part No : ALC888S. The audio output is single ended.
as per application requires a differential audio output.
Please suggest a single ended input to differential output converter IC of 5V/3.3V supply.
Thanks.
Regards,
Gopala
Thanks.
Regards,
Gopala
Thank you. Can you suggest me a transformer. With transformer does we get symmetrical signal. it needs to be support 600Ohm impedance.
Ssm2142 is another ic option.
https://www.analog.com/media/en/technical-documentation/data-sheets/SSM2142.pdf
