How to connect this choke
With little or no airgap the iron core is saturated and won't work well as choke. With too much air gap choke functions nice but inductance will be lower so the choke is less effective. When you make a choke first you need to calculate the thickness of the wire so the choke will not overheat and then you need to experiment to adjust the airgap of the choke.
