I am doing a 2way floorstanding speaker.The bas is cut LP with 6db,and the tweeter HP,now is there a rule how to connect the phase of the tweter?
In phase or out of phase,or is it ti try and listen?
Just connect the wire coming from the capacitor of the HP to the red or + of the tweeter.In phase
B.L
For a 2 way the most common targets are L/R second order and L/R fourth
order. for the former the tweeter phase reversed, the latter in-phase.
rgds, sreten.
undefinition
Zaph|Audio
FRD Consortium tools guide
RJB Audio Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
Humble Homemade Hifi
Click below to go to
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
rgds, sreten.
undefinition
Zaph|Audio
RJB Audio Projects
Music and Design
I did filter my speaker and maesure the phase and spl and corrected it till it was the same as with my sound card input connected to output.
So I tuned the low response then the high response then to gather result perfect phase and very linear.
What software did you use to messaure the phase?
HBX V6 You have to know German to use it. And you have to pay for it.
HBX6
It can measure TS-parameters of your driver.
- How to connect the phase in 2 way?
