How to connect 4 speakers + 1 Subwoofer
Hi... Im new in this forum and noob in audio world. Recently my father gave me his classic home amplifier made by Rotel(brand from Taiwan i think). This amplifier have 4 outputs speaker(there is 4 positive and 4 negative connector) but there stated at the rear of the amplifier Speaker A and Speaker B(2 speakers? So confuse). currently i connect 4 cheap speakers just to test the amplfier. I also got a 8inch subwoofer but i dont know where to connect it on the amplifier since there is no connector for subwoofer.
My question is how do i connect those 4 speakers and the subwoofer and make it work correctly?
You can run all four speakers at the same time if you select 'speaker A + speaker B'.
In this configuration, all four speaker must have an impedance of 8 ohm or more to avoid damaging the amplifier.
If you want to choose between two pairs of speakers, then select 'speaker A or speaker B'. In this configuration the minimum impedance of each speaker can be 4 ohm.
If your 8" subwoofer is passive (no built in amplifier), then you can't connect it to the Rotel.
