On the double-BJT CCSs employed for the LTP and the VAS, I've seen them with the second leg taken to ground, and with the second leg taken to -V (as in the above drawings).
Are there advantages to either, or are they equivalent?
Thanks, ZM.
I ran into an interesting limit for the VAS current. Increasing the current requires increasing the LTP resistor to maintain a 0 DC offset. However, at some point the voltage drop over the LTP resistor starts to eat into your swing and clip the amplifier.
...with the second leg taken to ground, and with the second leg taken to -V...
It's only a personal opinion, so worth nothing.
I avoid connecting things to ground, idealy there should be no DC current flow on the 0V rail; the only current flow should be the input signal current, the output AC current should be returned to the PSU where it came from.
