How to choose Neutrik XLR?
IMO all neutriks are good, so pick the ones you like, The EMC series do a good job helping direct RF to where it should go. But you are unlikely to need them in a domestic setting. However peace of mind is worth a few SQ points 🙂
Neutrik X series and Switchcraft AA series are my go-to XLR cable connectors.
Unless you're stringing XLR cables between equipment racks at a radio broadcast site or other stupidly-high-RF environment, you probably don't need the EMC series. And even if you do, snapping some ferrites on the cable ends works just as well.
I'm also looking at using some DIY Neutrik cables for my active loudspeakers. I looked at the Neutrik website and the X series that gmarsh mentioned. When you use these connectors which end is on the cable male or female? Thanks, JD
Thank you.
Bicefalo, I will order some XX-HE series next time.
I will also try EMC series and Switchcraft next time.
At the moment, I have little idea about how different series work.
I need PCB mount connectors.
I ordered a few D-series connectors for my PCB work.
Also, I ordered some XX-series connectors.
I use the NC3MXX-B and NC4MXX-B in all my projects, I think they're great.
I've used the NC3MXX-14 for a higher current project too (battery charger).
I use the NC4FBH for my board mount jacks.
If you're looking for board mount 3 pin female, I would go with the NC3FBH2. The separate pin 1 and chassis ground gives you more options, including tying them together if you want.
Yup.
I ordered some NC3MXX-B, NC3FXX-B as well as BAG version. As I am switching from single-ended system to balanced. I have no prior experience with these connectors. So, I ordered more models and see which one fit my personal preference.
For PCB mount connectors, I ordered some NC3FD-H-B and NC3MD-H-B.
Redshift, thank you for your input.
I was confused when I found some models have an additional pin but some model don't.
