Many years ago with the help of people in this forum I built a sub with a driver I had, a 10" which was pretty good.
That sub has been dismantled years ago. And I'd like to build a new one, to go low.
The room I'm running it in is only 3x6 meters so it doesn't need to be ridiculously loud. But I'm trying to find a good driver. The problem is that there are so many of them out there in the market, and I have no idea where to start
How can one tell if a driver is a good candidate? What specs should i look? Is it possible to look at the T/S parameters to quickly discard bad candidates?
Low resonance frequency, rubber surround, and suitable Qts for sealed.
What is wrong with your main speakers if you need a sub in such a small room?
