How to choose a driver for front loaded horn ?
Hello all,
I'm aiming to build a custom front loaded horn for an outdoor sound system.
The cabinet will be similar to altec m-17 (but smaller).
it should go between 150Hz and 1500Hz approximately.
I've been reading about horn theory and design. This paper (http://www.quarter-wave.com/Horns/Front_Horn.pdf, page 16) says that good driver for horn should have Qts between 0.15 and 0.25.
These are however difficult to find in 10" and rather expensive
my choice came to this driver RCF L10 750 YK
with this indicated frequency response
and those T/S Parameters
  • Resonance frequency (Fs): 68 Hz
  • DC resistance (Re) (ohm): 5.10 ohm
  • Mechanical factor: 4.20 Qms
  • Electrical factor: 0.25 Qes
  • Total factor: 0.24 Qts
  • Bl factor (Bl) (T x m): 17.50 T x m
  • Effective moving mass (Mms): 36.0 g
  • Equivalent Cas air loaded (Vas): 26.0 liters
  • Effettive piston area (Sd): 0.040 m2
  • Max. linear excursion (Xmax): 3.0 mm
  • Voice coil inductance @ 1kHz (Le1k): 0.50 mH
  • Half-space efficency (Eff): 3.15%
But i Would like to know : WHAT PARAMETERS SHOULD I CHECK FOR DRIVER IN ORDER TO BUILD A FRONT LOADED HORN LOUDSPEAKER ?
Thanks in advance for your answers !
:happy1:
Alix
[Alix, here is your image. Imgur doesn't like other sites linking.]
Consider the efficiency bandwidth product. EBP=Fs/Qes. Larger values indicate a stronger motor suited to creating pressure against a restriction. EPB should probably be larger than 100. I like to confirm with hornresp.
After using Bruce Edgar papers for building a midbass horn I kept using 2xFs/Qes as the upper limit for which a driver is suitable for. When searching for a proper driver to load a horn look after a not so low Fs (for example, over 60-70Hz) and high Bl value (big magnet for the motor). Your driver si optimal to 2x68/0.25=544 Hz .It's working over that limit but would need some kind of EQ.
