How to cancel odd order harmonics?
Certainly it's easy enough to achieve such an effect, and Iinvented two of them - one which injects current into the base
of the output all the time, and another which was the one I
patented in 1976. I didn't choose to use the former, but I
noticed later that Technics picked it up in one of their amps.
I didn't use it because like the SAE design, the output devices
remained on, but the signal passed through diodes that did
switch on and off, so you couldn't argue that the signal actually
passed through devices all of which were always forward biased.
Is your first idea looks like this, Mr. Pass? I never built the prototype, because I also think that the finals can be non-turnoff, but the diodes will turn off.
smoking-amp said:
Any mirror designs around that get really large current gains, like 50 or 100?
This is my High-Scale Current Mirror.
The scale ratio of this one is about 50.
The scale ratio of this one is about 200.
I have studied to use such Current Mirror on power amp for several months.
Our Cup Runneth Over!
re: wensan and xocoatl
Wow, now we have a bonanza of high gain/ high current mirrors.
Anyone have any typical distortion figures for these? This capability could really change the picture for amplifier designs. ( wild visions of composite V-I output amplifiers with ppm or better distortion figures racing thru my mind, or maybe low feedback amplifiers with good distortion figures too)
Perhaps, the long lost voltage mirror stage can be tackled in a practical way, finally, with some of these ideas too.
Don (who is freezing up in Maine at the moment)
I've played with all of these current-mirrors-with-gain on the end of the amp I've been working on here, but to be honest the simulations suggest that none of them are as good (in terms of distortion) as a plain old emitter follower stuck on a normal current mirror.
Some improvement to quiescent stability of the emitter follower can be had by partially feeding back the output current through a split emitter degeneration resistor, making it almost a current mirror, but even small values have a big impact on distortion.
Re: Our Cup Runneth Over!
This is the distortion figure that I simulate.
The scale ratio of Current Mirror is 200.
The 2nd and 3rd harmonic distortion less than 1%.
Re: warning
X.G. said:
I am not convinced of the CZ-1 sch of my post is correct,cause they are from the Chinese magazine which sometimes make errors:bigeyes: ....in my eyes,the current mirror circuit of it is wrong!😎 😉 ...The AES paper(super linear circuit,the 66th convention 1980 may 6) which wrote by Pioneer engineer don't show the details of that.
Yes, It's wrong. This is SLC circuit.
Do you have AES paper of SLC ?
Differential current amp
Finally found the article in my files. This circuit is a differential current amplifier that was in an opamp circuit by Mr. Rudy J. Van De Plassche in the Dec 71 IEEE JSSC. He used it as the load on a folded cascode LTP. It consists basically of two Wilson current mirrors with the diode in common. It has a current gain of beta.
Ray
