How to calculate Subwoofer enclosure bracing volume
Hi guys,
Hope you all are doing well.
I am building 12" subwoofers, one for my stereo system which is a sealed sub and other one is for home theatre system which is a slot ported design.
Sub RMS is 300w. So do I need to add heavy bracing for both. And how can I calculate bracing volume from internal volume. Is there is any tool's to ease the process.
Sealed internal volume is 48.5 litre.
Ported one is 73 litre with tuned for 28hz. Port area is 3" X 14.5" X 48"
Please suggest any solutions.
Do you mean you want to calculate how much bracing you should use, or calculate the displacement volume of the bracing you plan on adding?
If it's the latter, then it's fairly simple; multiply the dimensions of each bracing component in cm (e.g. a plate of 30x10x2cm = 600cm^3), then divide by 1000 for litres => 600cm^3 / 1000 = 0.6 litres.
If you're designing in CAD then tools such as Solidworks would definitely calculate the volume of material for you. SketchUp may even do it (though I can't recall for certain).
