I have three online calculators.
One is for calculating whether you should use ported or sealed.
Second is for a sealed cabinet
Third is for a ported cabinet.
The drivers I'm going to be experimenting are a pair of 3-way car 6x9 drivers.
They were free and available so that's what I'm going to be playing with.
I have the TS numbers for them from the manufacturer.
Singularly, they are equally suitable for sealed or ported according to the calculator.
However I want to make on single cabinet with both drivers in it wired to the L and R channel of the amplifier and the amp with take a mixed mono input.
Is there a way to combine the TS numbers together to treat the two drivers as a single driver and put those into the Second or Third calculator? Just add them or something?
Thanks,
J1M.
Thanks,
J1M.
I will be driving it with a 2 channel amplifier with the input signal mono'd between the input to the amp's little box and the amplifier itself.
I'll be mono'ing it with this resistor network:
Why Not Wye?
Hopefully this will mean that is suitable unlikely to happen.
Many Thanks,
J.
Why Not Wye?
Many Thanks,
J.
- Full Range
- How to calculate cabinet dimensions when using two identical drivers in one cabinet
