How to Bypass Relay on Sub Amp?
My subwoofer amp will not stay on. I have tried to bypass the relay switch but must not be doing it right.😕
Attached is the sub amp schematic and the Goodsky relay schematic.
Seems like it should be so simple... I have tried shorting across different points by the relay but the amp will still cut off. The power light stays green but that seems the only change.
I turn the amp off and wait a few minutes; turn it back on and get sound again.
Ughhh!!!! Please help???
Thanks in advance
View attachment 200W Subwoofer Schematic.pdf
View attachment Goodsky Relay RWRWH.pdf
Thanks for the safety warning.
When I short across one section of the relay the power light goes from green to orange, or from red to orange.
I used the same amp with another 4 ohm woofer and it worked properly.
Thanks again.
I have tried the amp with 3 other speakers -both 4 and 8 ohm and the amp shuts off. THis happens when the sub amp is connected to Harman AVR 154 sub output.
When I connect the sub amp to a small Tascam TM-D1000 digital mixer the amp stays on. Using -10db outputs on mixer.
