How to build the F5
Wow! That looks fantastic! -- I very much like the 'vertical tower' style.
Are your transformers on the bottom of the PSU stack? It's hard to see... Also, are you using lengths of threaded rod to support the boards?
Please keep showing your pictures of your build, I am very interested in seeing your progress. Thanks for posting!! 🙂
Hi 6L6
Tanks for the kind words.
Trafo / trafos will be on top of the capacitor banks the back is practically a separate enclosure
I am using at the moment aluminium sheet (500 x 320 Sorry for metric measures and aluminium bar 13 mm (1/2 in)
Yes it is treaded bar 4 mm to support the boards
There are 2 more PCB to go there auxiliary PSU and soft start and speaker protection.
At the moment width is 320 mm I would like to get that down a bit.
I am also planning on fitting 2 more banks of capacitors 1 for each channel on the space under the heat sinks.
Trafo is 1000 VA 24 V with a tap at 20 V (got 28V out of the 20 V tap)
Heat sink 300 X 400 X 83 bit on the big side for the stock F5 but should be enough for a triple balanced F5 or eventually B2 and maybe woodblock A75.
PCB again rough and ready home made (best thing I ever did was build a light box for the developing cost me about £50 but no more press and peal or toner transfer for me)
Once the case is ready apart from a lick of paint I fell it should be safe enough to give it same juice and start with the amplifiers PCB.
Here's a dry fitting of one of my channels (no goop, no solder);
I'm hoping crazy glue will hole one of the standoffs on the other heat sink.
Merlin, 6L6 and all......
I found it worthwhile to NOT solder the MOSFETs to the PCB while stuffing the board. I waited until I had the MOSFET test-mounted on the heatsink, and allowed the heatsink to "position" the MOSFET while I soldered it to the PCB. In doing this, it made certain the MOSFET had best possible alignment on the heatsink, without its soldered leads and the PCB "tugging" at it. For longevity, it also minimized the stress on the MOSFET leads and the PCB pads.
