Thanks guys,
Can I buy a NE5532 at Radio Shack or some other store?
or is there a place online that you recomend?
Nathan
Nathan
Sound of Silence
IF the phase inverter is built properly and the gain of both amplifiers on one channel is exactly matched, I reckon the result is going to be beautiful! Just what's needed for a good night's sleep...
Cheers
AndrewT said:Hi,
I feel like giving up.
I will just wait to see the posted results of placing the inverting circuit in front of one channel and then bridging the outputs of a nomal channel and the inverted channel.
I promise not to say "I told you so".
Cheers
AndrewT said:What's this
He posted a 'jif', as in Jif plastic lemons, as opposed to a GIF, as in Graphics Interchange Format.
I thought the Scottish would get it?.
Hi - Jif is a brand of peanut butter in good ol USA... (If memory serves!_
Cheers
Never heard of it, but a quick google proves you are right.
The same quick google also proves me wrong!, JIF is a new graphic format I've never heard of:
JIF, JFIF, JFI - another forms of JPG (Joint Photographic Experts Group: 24-bit support and fine compression make this format another standard for publishing on the Web).
Well now learn something new everyday! 🙂
Then again, the image posted has a GIF extension...
Nathan2 - how a bridged amplifier works: In bridge mode, two amplifiers work in tandem to drive a single speaker. This is accomplished by having one amplifier drive the speaker (+) and the the other drives the speaker (-). For this thing to work, ONE of the amplifiers (doesn't matter which one) must have a REVERSED signal compared to the other. Thus the need for a PHASE INVERTER. A phase inverter is a simple little circuit that just inverts (multiplies an input signal by -1).
If you take an amplifier system that is already bridged and add ANOTHER phase inverter , the two phase inverters working together will do this: (-1)*(-1) = +1. In other words, you get the original signal back, without any inversion. Net result - a speaker connected to the outputs of these two amplifiers whose signal outputs are EXACTLY the same produces NO NET signal across the speaker!
Hope this clears things up a bit.
- how to bridge 4ch to 2ch?
