I found a 22.5792hz crystal and it´s playing in the speed it should now.
By the way what does Fundamental mode crystal mean?
If the original clock circuit was sufficiently poor (which is possible) then this simple external clock might bring a minor improvement in jitter. If problems were due to the original crystal being low quality (also possible) then this circuit will make no difference.
Adding on such circuits with little or no understanding of what they do or how they do it or how to interface them to the CDP is as likely to add jitter as reduce it. However, any perceived change will be regarded as an improvement so everyone will be happy!
I have already collected parts to build the circuit and now found this thread and the above posting. A bit confused now whether to install the circuit in my CD player (Marantz CD5003)....
Roushon.
I have been running the Kwak clock ever since i built it,but I can´t swear that I hear any difference... 🙂
More confusion!😕
Edit: Also just noticed Elso Kwak is banned from this forum. Wandering why?
Why don´t you 2 try it,its easy to build it.
Yeah, I will build it. I have all the parts, just need to etch the PCB.
Roushon.
- Digital Source
- How to adjust Kwak clock?
