How should I connect this toroid?
I've bought some small 120VA for a couple of P3A mono blocks, but I don't know how to connect these . Can anyone help me out? (datasheet here)
I'm using only one bridge per amp.
What about the safety ground? It shouldn't be connected to the signal ground, right? So, I'll just connect to the chassis and leave the signal ground as it is, or...?
Any help is really appreciated.
(edited for swearing by pinkmouse :cop: )
Sorry about the swearing.. :guilty:
I think you might have forgotten the illustration... :D
UPDATE: I hope I've got it right: Violet and gray is connected to each other. Black and yellow is too. Red goes to the positive side of the PS and orange to the negative. Right?
sorry, here it is
I wish I'd found diyaudio.com a little sooner! I had EXACTLY the same noob-esque problem recently when building a PSU to power my CD player addon master clock. I asked a friendly guy in a hi-fi shop: Sevenoaks, always good for a chat ;-) His advice was [for 240v]: measure resistance, if it's double it must be series and hence correct. Simple! The most basic guidance is always appreciated...
-Simon
heres another newbie question for you,
is it possible to get a 0 volt, +24v, -24v from 2x toroids?
heres the catch
both transformers are 240volt primary, and 12volt secondary(2x secondaries, centretapped), the 2x primaries will be in series to get to 24v...
is it possible though to get a 0 volt ground?
